1 - 10 of 10 Posts
Looking to store maybe 10 gallons, my new buggy has a small fuel cell. I have a PJ buggy hauler with plenty of room. Looking for suggestions and it must look good too :flipoff2:
I've had Rotopax in the past but wasn't super impressed with the functionality.
Thanks dudes!
old school idiot
i used a salvaged aluminum boat tank once. was 30 gl, wide long and thin. cleaned it up so it had a brushed finish. pump and filter in the storage box, powered off the trailer plug. i think the whole thing cost like 30 bucks for the bungs. tanks are easy to make to fit anywhere you want. i just made 2 25gl tanks for my F800 for toy fuel
Someone will tell me why this is stupid, but why not just get a 19 gallon 80's Ford truck tank, they are like 5" tall, and use the electric frame pump wired off a switch and a battery? Tuck it up under the trailer and add a filler neck on the side and you're good to go?
old school idiot
been there done that back in the 80's, worked fine. was hard to route filler neck in a safe un cluttered spot
Banned
Because that wouldn't be "slick":shaking:
There's lots of flat tanks like that that could easily be re-purposed. A flush mount filler plug from a boat (or aircraft) solves the hose routing problem. Depending on your trailer frame width you could probably fit two fuel tanks side by side depending on what you get them from.
1 - 10 of 10 Posts
