1 - 10 of 10 Posts
i thought it would only be like 70-100 buks for all that crap besides the plate but i called and the guy said 200 buks for just the longer bearing and all that crap. wtf?! sheesh. its only 350 with the plate and 200 w/o it?! wtf!
sm420 bearings and stuff
Are you looking for a rebuild kit? If so check your local driveline or gear shops. This part #,BK108 from shop in Sparks cost $86 plus $6 for shipping. Pretty complete,with all bearings, snap rings ect. No synchro rings. I would also suggest replacing the bearing that comes with the Wardens plate with a sealed bearing and not use the seal that goes in the front of the t-case. That way you do not have to worry about possible damage to the seal as you install the t-case over the output shaft of the sm420. The seal or sealed bearing keeps the oils of the trans and t-case seperate. You can get the sealed bearing at Napa. It is a type of the 307 bearing. HTH
Mike
Originally posted by flexing40:
<STRONG>
Mike</STRONG>
Mike - any ideas about a re-build kit for an SM465 with synchros? I need to rebuild one. Thanks, Andy
hey guys! i work for a trans parts distributor and can get a decent deal on this kinda stuff. pm me with what you need and i'll do some digging for ya.
<IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0">
Dustin, go back and look at you signature line...that should clear matters up for ya. Besides one never really owns their cruiser, it primarily belongs to the bank, credit card companies and parts distributors the good news is you're young with lotsa earning potential <IMG SRC="smilies/tongue.gif" border="0">
Originally posted by KeithF:
<STRONG>Dustin, go back and look at you signature line...that should clear matters up for ya. Besides one never really owns their cruiser, it primarily belongs to the bank, credit card companies and parts distributors the good news is you're young with lotsa earning potential <IMG SRC="smilies/tongue.gif" border="0"></STRONG>
---:p true. but whaaa. 200buks damn! <IMG SRC="smilies/crybaby2.gif" border="0"> perhaps ill get the specs on all the parts and then have orangewagon get the same stuff that wardens feels is worth 200. jeff told me its like 20 buks worth of junk but well...supply on demand right... <IMG SRC="smilies/flipoff.gif" border="0"> . ill figure sumthin out. thew guy thats wapped it on extreme bends made his crap,right?
<STRONG>
Mike</STRONG>
-- oh and..no. i need the stuff tyo adapt it not rebuilt it but thanks dude!
Originally posted by orangeFJ45wagon:
<STRONG>hey guys! i work for a trans parts distributor and can get a decent deal on this kinda stuff. pm me with what you need and i'll do some digging for ya.
<IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0"></STRONG>
I would love to see a jobbers price on the N307LOE bearing needed for the swap. With the retaining ring if possible. I might consider buy a quantity and making them available with my adapter plates. Best price I found was $38 before shipping and handling. E-mail direct if you prefer
Mike "SpaceGhost" Smythe
[email protected]
Dustin,
the only thing you "need" from Warden's is the 2F pilot bearing kit. Very reasonable for the $50 they charge (at least they were a month or so ago). Everything else is from Toyota (new seal, gasket, and washer) or Napa (SM420 gasket kit) and the local nut and bolt supplier (tcase bolts, studs and washers, and the adapter to tranny bolts and washers, and a roll pin) and the N307LOE bearing which should easily be less than $50.
That's asuming you are not going to use an indexing ring (which I don't think Warden's sells anyway). If so add that in as well.
If you started with a 4 speed (flywheel and pressure plate) add in $70 or so for the clutch disk.
I'm somewhere around $275 - $300 total (plate, ring and clutch disk included) saving at least $150 over the kit prices (that are short the ring and clutch disk).
What did I do wrong?
[ 10-24-2001: Message edited by: SpaceGhost ]
1 - 10 of 10 Posts
