1 - 5 of 5 Posts
I was looking through my "tech" book Ive made through years of magazine clippings. Anyway I was looking for SM 465 rebuild type shit and stumbled across and article I saved from back in the day on the "Iron Giant" in there I found info on solving the 3rd gear pop out with a few items this company makes. First is a sleeve that replaces the snap rings between 3rd and 4th gear...its a whopping $11.25 Also they make a set of heavier shift springs for the shifter rails, they were 5 bucks a peice. Anyway thought Id share as Im about to rebuild mine and thought this was pretty cool stuff.
Anaheim Gear 1-800-477-1103 www.anaheimgear.com
The sleeve and snap-ring go on the counter gear on the early models. The factory had problems with the original snap rings holding 4th gear in place. The fix was to remove the factory snap-rings and installl the sleeve betweeen third and 4th and then put a heavier duty snap-ring on the outside
syncros are a brass clutch ring
the actual dogs that drive the gear is what I am refering to, in that there is some sold as the solution to the "kickout problem"
IMO the solution is to ensure full engagement
1 - 5 of 5 Posts
