1 - 20 of 21 Posts
how many people running rockwells with small blocks? i know big blocks would have no problem but what bout small blocks? and if so are you using auto's or standards?? thanks......doing some research for my "little" project.
while there's a rockwell post handy....
sorry to hijack the thread, but i've got a rockwell question too. the front axles have centered pumpkins, so what are you all doing for a transfer case?
Stroker SB=more torque than stock big block.
Also, with the deep gearing of rockwells, you need something that can twist anyways. Rockwells don't weight THAT much anyways.
I'll be running a 4cyl and standard with my rockwells.
Pumpkin isnt centered, its set to the pass. side. Like in the pic.
Bullshit.
ok, good start. sorry, but i don't see why you need rockwells with a 4 cyl. you were just kidding right? i'm curious cause i have a set of GMC 2 ton axles, they only have 6.17's but i would like yous guys thoughts on how a 302 would handle a set of 44's with this gearing. i know the gears are deep, but that is a lot of gear to turn as well. give some feed back. it will all be in a ranger, so the rest of the rig will be very light. but i'm scared a 302 with an auto would not have nough ass to get around. thanks................
uhh the deep gearing makes your motor seem bigger, not smaller:rolleyes:
I run my original cruiser 2F and it has way more acceleration than with the stock cruiser axles...
And yes, he was serious about runnin a 4 cyl with rockwells...
Discussion Starter · #9 ·
ok, i can understand the gearing helping. on to my next question them, should i beable to run a auto behind a very mild 302 and still run down the road? i can get the auto for very good price, but if it will be a dog i won't do it. thanks for your thoughts......
If I understand correctly, you are asking if a small block will be able to turn the gears in the chunk? Why wouldn't it? The difference between turning gears in a small rear end and a large one are negligible. You seem surprised that someone is able to use rockwells with a 4-banger. It's no harder to turn the rockwells than it is the Toyota axles.
Now, moving the truck around because of all the extra weight, that's different. :flipoff2:
This is beginning to sound like a DAN question.
Discussion Starter · #11 ·
ok, everything in you drive train eats power. you start with your crank hp. them the power travels through your trans, in this case an auto, which eats up a % of power. next the t-case, in this case is rockwell case size takes another %, get the idea. and so on through the front and rear to the tires. each componet requires power to turn. and 44" swampers take alot. i just want to have some power left to hit the pavement, mud whut ever. so i would like all the input from people like you 350 Samurai, i asume you have a 350, rockwells and are thows 44's? but do you run an auto or stick? and if you have ever driven down the road how'd it perform? i really appricate the input guys, thanks
reddwarf said:
Whaaaaaat?:rolleyes:
Ok, big block = bigger bore, longer stroke (aka more cubic inches), bigger ports
How much $$$ do you have in the stroker????
I think he is compare a fairly built stroker to a stock smog era stock big block. Also not taking into account the huge torque of a big block from 1000-2500 RPM right were we need it. I would imagine a stroker making even close to big block torque would be making most of it around and above 3000
i run 52 goodyears and michelin s with a ford 300 6 cylinder and a t 18 with a 208 t case plenty of power road manners are horrible at best 30 mph is pushing it too much death wobble even with the hydro steer
i run a stock 3f 6 cylinder in my cruiser, it weights in at 6k+ it woorks better with the rockwells than it every has. and i can cruise down the road better than ever. mike
1 - 20 of 21 Posts
