I need help finding a starter. I have an 82 Scrambler that originally had a 151 iron duke engine. The bellhousing bolts directly to my chevy 350 that has a 153 tooth flywheel. All matched up great until I got to the starter. My chevy block only has 2 holes for a starter (not 3) and they are the diagonal pattern. I can only find a starter with the diaganol pattern for a 168 tooth flywheel. All gm starters for 153 tooth that I have found have the straight across pattern. Has someone else ran into this problem? My next step would be to try to drill and tap the block for the missing hole, something I didn't want to do.
