1 - 20 of 29 Posts
Well.......
Just post up any little tricks or whatever you know of to hlep get through smog. This is assuming everything is working, but for say a motor that's tired and burns oil or whatever.
~John
Just for clarification, an engine can burn a crap load of oil, and still pass smog, just make sure the oil is clean. In other words, buring oil does not make HC, and CO numbers higher. BUT, oil can easily be contaminated with fuel, and cause those numbers to rise.
Spark plugs can make a difference too. I went from fail to barely passed on my DD 84 Sentra 4banger. Next year gets a new PCV and that junk in the tank that says it'll make ya pass no mattah what!
Wut?
My tricks:
1) new plugs, one stage HOTTER put in day before test
2) run a full tank of 76 super, with a bottle of 104+ AND a bottle of "smog check" (get this at pep boys) [WARNING: this lifts your octane to almost 106, be aware you WILL knock and ping if you are out of tune. Last time I did this I was running a 6AL and still had pings]
3) after filling up, drive right to the shop, stay a gear lower than normal, you want to heat the motor up nice and hot.
4)as everyone said, PRETEST.
5) if your prestest comes out bad, you can cheat a little bit. Install a brand new catlitic converter, then bore 2 holes 1/32 in size, about 1 inch and 2 inches back from the muffler. This introduses air into the exaust. Drill them on top of the pipe, and drill NO more than 2. The test computer will pick up the mod if you run them to big..and fail you. Its a bit tricky to get the right mix of air to trick the system, but it can be done.
You are on crack. higher octane fuel does not burn completely. Try 87 octane buddy. And it's not heat the motor up nice and hot, make sure that cat's hot. Also if your pile burns excessive amounts of oil replace it, the burnt oil clogs up the catalyst. And do change the oil and make sure egr and air injection (if applicatable) are in good working condition.
I used to work for a brit car shop and we had to have the late 70's POS's pass the sniffer test here in Texas. Here is what we would do:
Oil change
Clean out the jets in the carb
Lean out the mixture
Retard timing
Add RXP (small red bottle, available at PepBoy's, O'reilly's etc. This stuff was actually suggested by the guys running the machines)
The car was slow as hell getting to the test center, but the number were low enough to pass.
Brandon said:
If it is carbed, a computer controlled one will lean itself if cold - less emmissions. Therfore yank the tstat if it is computer controlled before the test..
Hate to break it to ya, but a cold computer controlled vehicle runs richer to help warm it up;) Thats why there is open and closed loop operation.
Brian--
blacklabjeep said:
Retard timing
If you retard the timing, it will slow the burn, and get lower HC readings, however, when the tech checks your timing, and realizes that the timing is not in spec, you will be failed:(
It might work in Texas, but not in California
My 84 had new plugs, new cat, and new oil. Still failed. Burning to much oil. So I removed the hose that goes from the valve cover to the air cleaner, stuck a bolt in the hole and slide the hose over it. Then under the air cleaner where the PVC goes to the Carb base plate i did the same thing. I think the motor had to much blow by, and when I did this it passed smog. Just barely, but good enough for me to sell.
1 - 20 of 29 Posts
