NOTE 1: The following Calibration and Flat Rate prices do not apply to a product that cannot be
calibrated due to abuse or tampering. Such products will be returned not repaired.
NOTE 2: Unless stated in the product service, Calibration Certificates are not included in the Flat Rate
and Labor Rate prices. Calibration Certificates must be ordered on the Service Order.
(See Calibration Certificate Options below).
NOTE 3: Calibration Only is applicable when repair is not needed in order to calibrate the tool. When
the torque wrench is found to require repair, the normal Flat Rate will be applied.
(The Flat Rate program does not provide estimates).
NOTE 4: The test equipment and standards used to calibrate torque products are traceable to NIST
(National Institute of Standards and Technology).
NOTE 5: TBT600 sensors and digital displays must be calibrated as a system.
(A sensor cannot be calibrated without the digital display).
NOTE 6: Some older model torque wrenches can no longer be adequately serviced due to unavailability
of parts. (This applies to models TQ1 through TQ2000, Q150 through Q3150F, QC117 through QC4600,
QTS130 and QTSP130, QJ4400 through QJ4600 and QJR4600A, QJR104 and QJFR275).
NOTE 7: QJR4600B and QJR4600BB models are serviced at:
Angle Repair Service
175 Angle Drive
Berkley, Wv. 25801-8447
Phone: 800-573-0037
