1 - 20 of 66 Posts
Picked this up last summer decided I should do something with it. Without the frame all I had go by was a hacked up frame I had. The bonus was I had papers for it.
Welded up some rails
Discussion Starter #6
Backed up the junkyard 5.3 with a 4l60e and a northwest fab black box and a cruiser case
Discussion Starter #7
Rolled the narrowed 14 bolt and fj 60 diffs under it too get an idea what the wheel base should be
Discussion Starter #8
Pulled it all apart to fish plate and add needed brackets to the frame.
Discussion Starter #10
Lol never know
Get back to your plan B v3.9 or I might be wheeling before you
Discussion Starter #13
I should probably mention I made the new frame at 30 inches wide which should allow me to use fj60 steering
Discussion Starter #14
That also helped with putting the drivetrain between the rails
Discussion Starter #15
Got the rear suspension tacked in place last weekend next up is the front
Discussion Starter #18
Front axle was originally built for a landcruiser bj60 sixty that ended up have too much frame cancer.
Of course all the mounts and high steer had too go.
Currently stripped of the leaf perches and marlin high steer was swapped out for stock arms
Discussion Starter #20
With my knuckles being swapped for the front range off-road Tacoma kit the old caliper mounts are now on the front so I want to tie into those for the steering arms
1 - 20 of 66 Posts
