1 - 14 of 14 Posts
I want and need to do a snorkle on my 82`Toy. I have a weber carb. and i cant find a kit for a carborated toy. Is thair a kit out thair that will fit a weber? Has annyone made a box to go over the carb. whith an out let to go up the side of my truck or something? let me know whut yall done. Ineed to fix this pesky water going in my engine problem since the water season is coming. THANKS!! <IMG SRC="smilies/clown.gif" border="0"> <IMG SRC="smilies/bounce.gif" border="0"> <IMG SRC="smilies/clown.gif" border="0"> <IMG SRC="smilies/bounce.gif" border="0">
I've got just what your lookin for.. I'll try and post pics tommorow. <IMG SRC="smilies/bounce.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0">
I used a rubbermaid container, about 5 ft of 2" pvc and some rubber hose.. Cost me about $30.00 Now, where did that damn camera go...
K&N makes an adapter that's made just for that reason. I don't have the part # handy though. My Weber has an adapter that allows me to use the stock air filter housing which simplified my snorkel installation.
SO here is how mine turned out.
<IMG width=640 height=480 SRC="http://www.pirate4x4.com/ubb/uploads/MVC-021F.JPG">
It is hard PVC from the inner fenderwell up.
<IMG width=640 height=480 SRC="http://www.pirate4x4.com/ubb/uploads/rino snorkle 2.jpg">
I took the rubbermaid container and traced out the top of my Weber and then cut it out. The factory weber base plate fits inside and bolts to the top of the carb. Can use stock aircleaner and everything. I also routed my front diff breather in there to. I do have a little air restriction due to the 2" pipe. SO I usually run it with the top off when not in water. Otherwise works real good.
<IMG SRC="smilies/eyemouth.gif" border="0"> <IMG SRC="smilies/eyemouth.gif" border="0">
Hey Rhino, thanx!
I'm running dual Mikuni DCOE's, and have been trying to figure out how to come up with a way to adapt a snorkel to them.........A few seconds after seeing your pic, an idea hit me......Thanx!
<IMG width=288 height=216 SRC="http://www.pirate4x4.com/ubb/uploads/Darinenginesmall.jpg">
I plan on adding a snorkel after I go to 'glass fenders...my new aircleaner box is now on the passenger fender and already has a cutout for snorkel attachment......love those engine swaps... <IMG SRC="smilies/blender.gif" border="0">
TWM makes one and I know Downey used to sell one too. It's an aluminum plenum. You bolt the bottom plate to the top of the carb and then the plenum part on top of that. It has a ovalish shaped opening that you run a hose to. They work great, I did a blow through turbo with one. you can try to rig up something but for the money I would just buy one of these.
I was trying to figure out how I was going to put a snorkle on my weber, and was thinking about having a shop make some sort of piece which would bolt on in place of the air cleaner with a fitting to hook a pipe up to it.......but I never got that far.
1 - 14 of 14 Posts
