1 - 6 of 6 Posts
I finally broke down and bought the welder I been looking at.
You may have seen my earlier post on weather or not I should get it or not but I got it now I have to run a wire to my detached garage for it. What size wire does it need.
Welder is a L-Tec 250 amp 220 welder
the metal card on front says 27 volts and 57/52 amps
plug is standard welder 3 prong plug
any help is appreciated
Ahhhhh, you need lots of it :confused:
Seriously, the size of the wire depends on the length of the run. But always err on the larger size.
the run from the main box will be around 40ft so I was looking at either 10/2 or 8/2 but I just dont want any issues
is he talking about the power wire or the welding filler wire?
for the power wire just read the wire thats on the welder and go down 2-4 guages. bigger will never hurt.
for the filler wire it depends on what you want to weld.
what I now know is the welder draws 57/52 amps so I needed at least 6/2 copper. If you have priced this stuff lately its redicilous. $2.64 ft. I wound up getting 100 amp aluminum 2/2/4 service wire and this will be run from a main breaker panel to my garage for a box for my welder this 2/2/4 wire was onlt $1.17 a foot
1 - 6 of 6 Posts
