Finally got to the point of fitting the perches to the axle housing on my front axle. I bought the Mopar perches from the part numbers on Woody' web site, (thanks again for the short cuts)
Anyway, the holes in the tops of the perches are MUCH larger than the new spring pins that I have installed from SOR. Should I weld in a washer type bushing in the perch to hold fast to the pin?/OR will it be OK under the properly torqued U bolts?
