I yanked the ABS on my ex's 94 4Runner when we installed the 4" lift. Hated that crap anyway.
Pull the fuse and delete it, in my opinion anything as modified as most of our rigs are the ABS won't work properly anyway. One trip i made to hollister i was hit by a 98 chevy that was lifted with swampers, which made no difference because the ABS kicked in and the poor guy drove right into me, foot on the brake the whole time. My .02So I have purchased a 81 front solid axle for My 95 toyota Runner V6. The runner has ABS on it, but was wondering what people were doing about the abs part of things when doing a SAS? Any Ideas? Do you have to press a ABS ring onto the hub, or?
While I tend to agree as far as trail use, 4 wheel ABS is a wonderful thing on icy roads in a DD vehicle. No pumping, no threshold braking, no guesswork. Just bury the pedal in the firewall and steer like normal, and it pumps the brakes far better than you ever could.the abs on your runner is rear wheel only.
abs is for people who cant drive
funny thing....i was at hollister in my old ranger doing a hillclimb, hit a rut and stopped, hit the brakes (pedal hard as a rock) and proceeded to fly down the hill backwards and smashed into the hill at the bottom backwards doing probably about 25-30. Brake pedal didnt move and inch the entire time. Thank god for my rear tube bumper, took the brunt with no damage. ABS blows...One trip i made to hollister i was hit by a 98 chevy that was lifted with swampers, which made no difference because the ABS kicked in and the poor guy drove right into me, foot on the brake the whole time. My .02
As every one else has said it is rear wheel only. I cut the lines to the pass side abs unit made a loop and connected the lines it has going in and out together then remove the unit from the frame. I then cut the connector at the harness and took the bulb out of the cluster and then cut the wiring off ath the sensor and at the frame. No more abs.So I have purchased a 81 front solid axle for My 95 toyota Runner V6. The runner has ABS on it, but was wondering what people were doing about the abs part of things when doing a SAS? Any Ideas? Do you have to press a ABS ring onto the hub, or?
Because I want to get rid of it completely without pulling the bulb. I am removing the block alltogether and want to get rid of everything else at the same time. I dont want any trace it there being abs in my 4runner because if there is then it will fail when it comes to an inspection.As every one else has said it is rear wheel only. I cut the lines to the pass side abs unit made a loop and connected the lines it has going in and out together then remove the unit from the frame. I then cut the connector at the harness and took the bulb out of the cluster and then cut the wiring off ath the sensor and at the frame. No more abs.
No I get that I said cut off the brackets, make a union line to connect the two brake lines together, cut the wiring out in the front and rear, then remove the bulb because it will most likely be on. All the abs should be gone by then if you remove the controller off of the pass side frame rail.Because I want to get rid of it completely without pulling the bulb. I am removing the block alltogether and want to get rid of everything else at the same time. I dont want any trace it there being abs in my 4runner because if there is then it will fail when it comes to an inspection.
