Here's how I'm doing it. I did a rear 4 link 3 or 4 years ago and I have been accquiring the necessary parts for the build. I'm working with a 70 800 with a power lock Scout II front end and running 35's a Fuel injected 345 and a 727 auto.
The objective is a capable all around rig and probably sticking with 35's for a long long time. Here's the link to the rear build. http://www.binderplanet.com/forums/showthread.php?t=52069&highlight=link
Here is the parts list...
I'll be using 2" 12" travel FOA coil overs withg dual spring, 14" - 350# under
10" - 225#.
The new axle is a D-44 RS from a 78 Ford. The long side is now the short side and the left side was retubed to stock Scout II length. Right now, the Short side is set up to run a EB short side which is 3.5" longer than a stock Scout.
The overall width is the same as the current axle because I am running 1-1/2" spacers. The reason I am doing this axle is the Scout II D-44 has about 2-1/2" of right tube and I don't have room for the brackets and keep the lower links paralell and under the frame so I don't loose turning radius.
10" - 225#.
