Well here it is... What do you think? http://www.full-traction.com/boltonspoa.htm
I have to agree, they are absolute crap. If it where a pavement queen only I could see the use of it, but if you have any clue how to weld I would just get some spring perches and do it yourself.jeepboyben said:Well considering you can do the same thing properly for about $30, and some time behind a welder. I'd say over priced, clearance limiting JU crap. That is what I want, my spring perches clamped to my axles so they can loosen up, and I can throw driveshafts, and cause scary steering at random times.
1978CJ5 said:Well here it is... What do you think? http://www.full-traction.com/boltonspoa.htm
Don't forget a 3" hole saw to make your purches from 2x4 stock. I have done at least 20 SOA's for different folks and have never had to spend more than 30 bucks for the material. $100 if you buy new U bolts. Total waste of money.Pottsy said:
Well, My true thoughts are..."I think $500 bucks is way to much money for that..."
Take your $500 you are going to spend on that kit and buy:
$200 Lincoln 220v 225amp Arc/stick welder.
$200 Dewalt chop-saw
$70 4 1/2 inch angle grinder
______________________________________
and build your own SOA kit.......![]()
These items will save you more money over the next 20 yrs then that $500 SOA kit will......:flipoff2:
You ask.... I told....
