Try heating up the ends and not just the cable. That's what I did. Worked very well. I also used my small portable oxy/acet kit on a soft flame.
Actually, I was only going to fill it about 2/3 full for that very reason. But that is a good point to bring up.Aces'n'8s said:If you use that pipe deal, you should try to put a lip on it. Otherwise, I would think you spill hot solder everywhere?
xjbrett said:I just use a 1" copper end cap as a melting pot. Not a lot of capacity but works for what I need it for.
kwrangln said:I've replaced plenty of connectors, ground clamps, and stingers, never bothered to solder any of them, never a problem. Cant see it doing anything but helping, but if those clamps and whatnot were designed to be soldered they wouldnt have the set screws in them. Come to think of it, I dont think I've even seen a welding cable with a soldered end.
I usually fill the terminal with solder, then throw it on the ground to coat the inside with solder, first. Don't know why, that's what dad taught me.MarkW said:I like to solder (tin) the ends, and then I hold it in with the set screw.
Over time it prevents the ends from fraying and the screw eventually digging through the cable.
No one seemed to pay attention to this post but he's right. Its the quickest and best way to do this. Del City has them. Linkolyfj40 said:You can buy solder lugs @ hardware store's that you can put into the connectors and then heat up with a torch, then you just insert the wire. That's what I do.
X2 on the copper end cap, Very good heat transfer, I just drilled a small hole and threaded a 2" 10-32 along the top edge for a handle to clamp in the vice to hold while tinning some 4 GA wire.
You should never sloder or tin welding cable connections! Is causes up to 5times the resistance of copper, and causes excessive heat.... this could also damage your equipment! They make copper sleeves to keep wire from fraying, otherwise just insert the bare wire and tighten the set screw.I have several welding cables, which I need to attach ends to. In the past, I have used a propane torch with a roll of solder, but that is a slow process. I thought about making a small melting pot, which I could heat with my acetylene torch. I could melt some lead in it, and add some flux just as I put the exposed end of the cable in.
Here's pics of the cable end and the small pot I was going to make. It's just some 3/4" ID steel tube, and I would weld a small plate to the bottom of it. Does anyone have a better idea for soldering several ends?
