1 - 12 of 12 Posts
For Kayla
I'm looking for the distance between the spring perches on a solid axle toyota... prolly 85 and under, front and rear (if they are different). say the outside and inside? if anyone knows what these are, I'd appreciate it.
29" on center , i second that :flipoff2: All kinds of info , in fact bout everything you want to know about SAS courtesy of......
SEARCH;)
I third the 29" center-center for the front, the rear is more but I don't know it off the top of my head
SEARCH;)
Hush newbie! :rolleyes:
Hey shane , wasnt pokin fun . There is tons of info if you search , just real hard to find it all as one subject could be under dozens of different topics . I'll go crawl under my rock again:flipoff2:
I found this (can't remember where tho), 85frame.jpg. should be pretty useful for any measurements you may need. hope this helps!!
link
For Kayla
SEARCH;)
did i say i was doing a SAS on an IFS Yota? No. I simply need the measurments. And like you said in a later post, all types of information can be found IF YOU KNOW WHAT TO SEARCH FOR.
I tried searching and didn't come up with anything. On top of that, I didn't want to wade through 9 million useless threads.
Now, if anyone has the rear measurements, that would be great.
And YotaCowboy, thank you for that Pic... it's actually going to help immensely.
Converting from that pic yotacowboy posted the rear is 39 3/8" on center, I can verify this later this evening if nobody else knows for sure.
the measurement at the shackle hangers is 740mm ( / by 25.4 = 29.13", but this isn't exactly the center of the tube). the measurement at the spring hangers (840mm) minus the thickness of one side of the hanger minus thickness of the bushing minus half of width of the leaf comes out to about the same (~29.45"). hope this makes sense. anyway, 29.5" width ctc is correct.
whoops, missed that part about "rear hangers". I've got my rear axle pulled (in the process of an sas and rear lift, lockers, etc...) and i'l measure tomorrow and get some 'real' numbers. sorry 'bout that... too little sleep
1 - 12 of 12 Posts
