Top shift Toyota t-case $150.
Forward shift Toyota t-case $150.
Forward shift 3rd toyota t-case $150 this one is still attached to the
Th350.
Th350 trans with shift kit $250
advance adapter th350 to toyota tcase $250
Dana 60 and Dana 44 Flange for Toyota Drive shaft $125
D44 and D60 with high steer, all seal's, u-joints, bearing's, tie rod ends, upper and lower ball joints, caliper's disc and pads All have 4 runs the gearing is 4:11 and the 60 is Lincoln locked $1500
High angle Drive shafts front and rear shafts $150
Front 27in collapsed 30 7/8in extended just before splines show 32in at extreme before it falls off but still together. Rear 51in collapsed 54 3/4 extended just before splines show 56 1/2 at extreme before it falls off but still together. flange to flange
Ford torus 3 wire Electric fan $60
Hydro assist $150 with the steering box.
Ram Info.
Rod Size: 1-1/8 in.
Stroke x Diameter: 8 x 2
Working Pressure: 2,500 PSI
Maximum Shock Rating: 4,000 PSI
53 inch chevy leafs $75 one pair
62 in chevy leafs $75 one pair
full hydro setup from plow off a 82 Chevy blazer
Two tune port fuel injected engines with one wiring harness and one ecm. One is a 79 Chevy block with 90-92 TPI this is runs great and is currently in a 82 CJ7. The 2nd is a LT1 out of a 89 camaro (86,000mi) I was told it ran when I bought it and has sat covered in a carport for the pass 1 1/2yrs. Iam restoring this jeep back to original
Iam sure there is more that Iam not thinking of At the moment. I will ship or deliver ON YOUR DIME
Any Q Call 906-485-5285.
Th350.
Ram Info.
Rod Size: 1-1/8 in.
