I just can't figure out the logic behind this thing...why??? All you're doing is sliding a small wheel to either join the inner and outer axle, or to leave them seperated. WHY??
So, to put your YJ into 4wd, you pull your t-case lever, which engages the front driveshaft and it also activates this vacuum thing to engage your right front tire. Is that the general idea? Am I missing something?
Why can't you just have a solid axle in there? Like a tj... I've heard you can put a TJ shaft in there...not really sure how the seal's work on that, but that's not the issue at hand.
Why have the vacuum???
