1 - 19 of 19 Posts
Ok ... there is quite the sound in the toyota when shifting a loud ssound cant really ecplain it.
Im curious if the valvs need adjusted or if I need something with the timing fixed.
thanks a bunch
Trav
Wicked Raciest !
SeaBass44 said:
what color is it?
:flipoff2: :flipoff2: :D :D :flipoff2: Thats funny Ron er I mean SeaBass.
clutch is 2 years old
I knew what it was in my Chevy, so I helped it along, launching at 5 grand and side stepping the clutch!!!!!!!!:D
johnygspot said:
^ that was funny you have to admit^
props to seabass
" Cheese whiz makes my eye balls itch.":confused: :confused: need to explain that 1 to me:D
catcher1 said:
could it be the timing chain?
Could be...he hasn't said 4 or 6 cylinder, but untill he describs it correctly in a manor where we can help him, we will just make fun of him untill he either smarts up or crys:D
Check your blinker fluid. If it's low, it might be bleeding past the horn's master cylinder dripping onto your belts causing the noise you're trying to describe:flipoff2:
you ass! toyotas stopped using blinker fluid in 85 same as the solid axle,we lost the good ones in 85:flipoff2:
My bad, I thought he had a 1st Gen. truck.
In that case he might just have an air leak in the t- case shift knob.
or
The air in the front left tire may be stale. That makes one helluva racket over 65MPH:flipoff2:
1 - 19 of 19 Posts
