1 - 20 of 20 Posts
I have been trying for DAYS to figure out what speed sensor is going to work on my 1993 4.0L engine going into my 1982 Wagoneer.
Someone posted that a "91-92 Dodge Ram" speed sensor is the same one that Hesco sells.
From my research, the one Hesco sells is a pass-through design, it screws into the speedo hookup on the transfer case, and then has a connector to plug into their harness. You then use your original speedo cable screwed into their sensor.
You can get this from your friendly :D Jeep/Dodge dealer for $120+ with Mopar # 56027015. Hesco's MPFI parts list states that they also give you #9400012 which is some kind of converter. My Jeep parts guy said that wasn't a valid Mopar/Chrysler number.
Someone that does 4.0 conversions told me that Nevada speedometer sells those sensors to Hesco. Nevada sells them for $95.95 but they are out of stock, and the lady I talked to there said they buy them from someone else. Unfortunately I forgot the name of where they get them, its something like Arthur Allen (AA) and the part # is AA1460-8. I called AA and the lady said she would call me back and tell me who would sell me one :flipoff2: but she hasnt called me back yet.
I tried 3 local car parts store chains, as well as Napa online and none of them have a speed sensor for a 91 Dodge Ram. I looked at the one for a '93 Dodge ram and it is a different design. Carquest had one for a '91 Dodge Ram but it did not have a cable pass-through
OK then I found on my '82 Wagoneer there actually is a cruise control sensor that connects 2 speedo cables together in the engine bay. It has a male+female 2 prong adapter. I went to the Dodge parts counter and the guy found a 1991 Jeep speed sensor that has a pass-through design BUT it is a 2-wire connector instead of 3-wire like my '93 harness has. The 1992 Jeep speed sensor has a 3 wire connector but it doesn't attach to the transfer case the same way, and there is no mechanical speedo cable hookup.
I looked at the wiring diagrams. 1991 Jeep 4.0 shows that the speed sensor uses a Blue wire to PCM pin #47 and a Brown/Red wire to PCM pin #4 that is common with the Sync sensor, coolant temp sensor, MAP, TPS, and air temp sensor.
the 1992-1993 Jeep 4.0 shows that the speed sensor uses those 2 ^^ wires up there as well as as a White/Black to PCM pin # 7 that is common with the CPS and sync sensor. What does this extra wire do? Why did they add it in 1992?
So, I would appreciate it if anyone has any info to contribute. I'd appreciate it if the people that said a 91-92 Dodge Ram sensor works to tell me where they got it, a part #, and how many wires.
The Hesco sensor is shown here:
I Assume it has 3 wires. I remember reading that Hesco's conversion kit is based on a 1994 Jeep 4.0 system. Hesco wants $80 for it. I would like to avoid ordering MORE stuff from them.
Otherwise I'm going to try to get my 2-wire cruise control sensor to work by hooking it up to my harness as the 1991 wiring diagram shows.
4.0 Wiring Diagrams
you can get the Hesco speed sensor from Jeepconnection.com fior $50 ish
if memory serves, the hesco sensor has 2 wires and the 4.0L harness has three wires. you abandon one of the wires, but I forget which. I'll see if I can dig up my notes.
I use a GM HAL 3 wire sending unit with my D300 autometer electic speedo combo. Dont have a clue if the jeeps HAL or not?
I called jeepconnection.com and gave him the part # for that speed sensor. I am pretty sure he said it would be at least 80 bucks. It isn't listed on their website.
I'd like to know how they adapt the 2-wire sensor to the 3-wire harness. Damnit, its frustrating how Jeep changed the wiring harness colors between '91 and '93.
wiring is as follows: Orange is the pos wire. This wire is abandoned when using the Hesco sensor, as the sensor itself generates the electrical pulse. White w/ orange is the sensor output to the computer. Black w/ lt. blue is the ground.
cross ref the part numbers from NAPA or the dealer for the two years. I believe them to be the same. do yourself a favor and keep good notes on your wiring. mine weren't the best and I still regret not taking more time documenting my work.
Discussion Starter · #12 ·
DE Jeeper said:
Also, you can have your local dealer cross refference the sensor that comes with the CJ Mopar MPI kit. I got it for around $50 and it pluged right into my '91 4.0l harness. HTH
My dealer tried to see if there was a compatible part # for it but he said there wasn't, and the local dealers would charge $120+. How did you get yours for 50? :eek:
prices have been climbing over the years.
I remeber when the sensor was $40 from Hesco direct.
you really have to love that the prices have DOUBLED with ZERO additional investment by Hesco. I REALLY hate those guys.
I really wish I had kept the number since this question comes up all of the time. I got the sensor trough the dealer that sponsors one of the Jeep clubs I belong to, but I bet you can find a dealer that will get you a better price then $120.
Just a note that Hesco actually sells an adapter to the 2 wire hookup. It's around $15.00. Might be worth it if you find the actual sensor cheaper elsewhere!
Good Luck!
I'm not positive, since I don't have a sensor yet, but PepBoys sells a lot of replacement connectors and they might have the connector that you/I need. That's where I got the connector for my backuplight switch on the AX-15 for my swap.
Tony W
I know this thread is 10+ years old but i actually just had to do this to my jeep and couldn't find this info anywhere easy.
mines a 94 XJ with a the early short shaft 80 dana300 with mechanic speedo.
Got the adapter with pigtail from advance auto for $30
BWD Vehicle Speed Sensor S8025: Get the best Speed Sensor at Advance Auto Parts
Sniped off the factory 3 wire sensor on the jeep thats white black and orange
Jeep ----- VSS
white ---> black
black ---> black white stripe
orange --- not used.
Done speedo works.
hope that helps somebody.
1 - 20 of 20 Posts
