1 - 7 of 7 Posts
I just changed my rear to 4.11 and I am showing 15mph off (more) which is normal after the ratio change...
I was thinking if I were to unplug the sensor (untill I get the correct speedo gear) would it affect the engine timing/computer ? or performance?
Does the on board computer use the speed reading to adjust the fuel etc?
I have a 95 Wrangler (YJ 4.0, fuel injected. ) It does use the computer for timing.
Thank you in advance..
Don't unplug it. Just leave it plugged in.
Ok.. it looks like the speed sensor does affect the performance. As soon as I unplugged engine would quit as I would come to a stop with gradual deceleration. No sputters, shaking nothing. RPM slowly goes to 0 and engine stop. Cant even notice it until you try to accelerate again.
I placed it right back.
P.s. It is a manual transmission
Speed sensor ? were is it ? are u sure its a speed sensor - sounds like the crank sensor
yes, unless its called something else....
its on the transfercase
and well my speedo & odo stopped working.. what else could it be? :D
I think the YJ with FI uses it (maybe). My RPM goes to zero or very low (when the speedo sensor off) as I come to a stop. With the speedo sensor on, it does not go below 500.
Anyway.. mystery solved. At least on my YJ 95.
BTW... What does the crank sensor do? Timing?
1 - 7 of 7 Posts
