1 - 7 of 7 Posts
Does anyone know where to get gears to recalibrate the speedometer on a toyota. I know they make em for jeeps but have never seen them for toyota's. Any one know??
Inchworm,
Is it just the inserted gear that is different. It's been so long since I tore down one of my cases I can't remeber if the output shaft gear is replacable. I'm in the same boat, I would like to recalibrate my speedometer.
Yes, the output shaft gear is replaceable there are at least two tooth counts there (I know there are 6 tooth and 7 tooth gears. There may be others.), and then a few different tooth counts on the plastic inserted gear. (18, 19, and 20 tooth. There maybe more of these also)
All of this is off the top of my head, I guess I ought to dump out my bucket of speedo gears tomorrow and see what I find.
If you can calculate what you need, I may have it. Let me know what you are looking for and we'll see...
Inchworm,
I like your idea but the problem is I am running 35in tires and 4.56 gears, that's why my speedometer is off so much. I will go ahead and see if I can figure out what ratio would work and you may have it.
I don't know who makes it or where it came from, but when I bought my 86 4Runner it had an adaptor on the speedo-cable input to the tranny. It screwed in where the speed-cable would, then the speedo-cable screws into the adaptor. It corrected my speedo with 4.10s and 33s and this is varified by GPS. I sware it was the most accurate thing ever <IMG SRC="smilies/smile.gif" border="0"> At one time I was geared to 4.88s and running 33s and my speedo wasn't as accurate as it was with the adaptor, 4.10s and 33s. Now w/35s and 4.88s my speedo is more accurate...must be a GPS thing <IMG SRC="smilies/smile.gif" border="0"> I wish I had a digital camera to show you guys what it looks like.
1 - 7 of 7 Posts
