1 - 13 of 13 Posts
Tera Low sells 3.15 gears for the Spicer 18, but I already have 2.46 gears. I can get the Tera gears for $500, but is that a waste of money? I will have a T-98 with 6.4:1 first gear, and 5.38's in the axles. I am just having a hard time deciding whether it is worth $500 to go from 84.7 to 1, to 108.4 to 1. I will have 38.5 SX's, and I don't really think either ratio will be low enough.
Did you talk to O'brian's Gear? He's in Sac, and builds gear sets for 18's all the way down to like 4.5 to 1.
I have heard no actual strength reports on these. I still run the 2.46 set behind a 4.3 Vortec and an SM465.
Andy
If that is the place I am thinking of the gears are like $1500 a set. I can't spend that much.
I have not really heard bad things about the Tera gears, and I will only be running a 4-cylinder. Did the guy breaking them have a V-8?
I would recommend staying away from Tera gears. In the small group of wheeling friends I have, 2 of them have had tera's in their 18's. They got a refund when set #5 went boom. V-6's, 33's and little skinny pedal between them :eek:
I have gone through 2 sets and each set only lasted one season so stay away of them is what I would suggest. Save all your $$$ and go to an atlas and a centered rear 60 and be done with it.
i think o'brien's are about it. I went Atlas at that point because I didn't feel there were enough people running O'briens to know how reliable they were going to be. Also with the cost taken into consideration I just said screw it and threw the extra money at it and got the Atlas. I just didn't want to look back and say, damn I should have got the Atlas.:D
O'brien's gears are very expensive, but if you want to stick with the 18 I think it's the only way to go. If you want to go to a center output, you might as well go Atlas for a few $$ more. I went to an 18 for 2 reasons: 1) rear output is ~4" lower- making for much better d-line angle when SOA on an 83" wheelbase 2) option of useing an overdrive (if he ever gets it into production).
I would'nt buy the Terra's because I do'nt think the difference is significant enough & they seem to have a reputation for breaking.
Discussion Starter · #11 ·
Unfortunately, I have an offset rear steer Dana 44. I don't have the Atlas as an option unless I start over on the project I am almost done with.:(
Is it the Tera gears that suck, or just the Spicer 18 design? I mean, will it be weaker with the Tera gears?
I agree totaly. After two sets and many hours on the trail removing broken teeth I went Atlas and centered.
1 - 13 of 13 Posts
