1 - 2 of 2 Posts
Spicer 3053A Transmission
Selling Spicer 3053A 5-speed OD transmission - from M35 Multifuel 2 1/2-ton truck.
Spicer 3053A Specs:
Approximate dry weight: 230 lbs
Case length: 13 1/2 in
Transmission ratios:
First or Low gear: 6.00:1
Second gear: 3.31:1
Third gear: 1.89:1
Fourth gear: 1.00:1
Fifth gear or Overdrive: 0.85:1
Reverse: 5.90:1
Main case material: Cast iron
Top cover material: Cast iron
Extension housing: None
Gear oil capacity: 9 pints
Gear oil type: 80/90 W
Maximum GVWR: 23,800 lbs (compared to NV4500 at 14,500 lbs GVWR)
Fully synchronized?: Yes
Input shaft: 10 spline, 1-1/2-in diameter
Output shaft: 10 spline, 1-1/2-in diameter
Located in Greenwood SC
$700 obo, possible trade for Dana 60,14 bolt
1 - 2 of 2 Posts
