1 - 20 of 130 Posts
ok so i bought a sammy for 3k with the spring over, 4 to 1 tcase gears,and 1k worth of boggers
I thought this thread was going to be about creaky leaf springs....
Nice find on the rig. Worth it just for the shoes it's wearing.
so the motor was smoking bad and the weber carb flooded on every steep hill climb. a good friend sold me his project sammy for parts and a good 96 1.6 liter with harness and computer for $400.
yeah ive made a bad habit of buyin trucks for the tires
now at this point im just learning about ecms and such so i shelled out the 500 for trail toughs 16valve conversion
the jackass that rebuilt the transfercase last didnt get a ne countershaft or needle bearings.nor did he remember to remove the speedo gear first which resulted in this
cant remember how much that cost me but i rebuilt it again.but to this day ive had a problem with it snapping out of gear ive installed shims/upgraded output shaft,flipped the coupler over to nice new teeth and notched the body in front of the shifter because i believed the body lift was causing a clearance issue. so im gonna fab up a tcase cradle similar to zors snatch to mount it more solidly
my buddy who sold me the sammy also gave me some teraflex dropout shackles which i tried but i didnt like how shaky it was at speed so i fabbed up my own missing link setup with a ruf conversion.It helped a lot with the extra weight of my new winch
Discussion Starter · #10 ·
The last pic was the teraflex installed by themselves this is my ruf/missing link
Discussion Starter · #11 ·
If only you had some Toyota's to go under it.
not to worry ive got toyotas with longs and 5.29s under this amigo i recenty aquired from a friend who was burnt out on it
Discussion Starter · #13 ·
i need to lower the front end on the amigo and ive got to wire in the fuel injection on the 96 blazer 4.3l vortec.any body got an example of a bare bones modified wiring harness?
this is my diy histeer
Discussion Starter · #14 ·
were going rockcrawling at katemsy rocks in september. The last time i didnt have powersteering or highsteer so this time ought to be more fun. heres my diff guard
Discussion Starter · #16 ·
oops take 2
Discussion Starter · #17 ·
funny story when winch a 10,000 lb truck you should not tie your rear bumper to a tree.the good news is the rear bumper is the one i welded on.
what steering box are you running and more pics of how its mounted and what size tires are those?
1 - 20 of 130 Posts
