1 - 8 of 8 Posts
FYI 25mm = about an inch.
One of the best tools I have is my $2 plastic slide caliper. It'll take inner and outer measurements up to six inches. Makes measuring stuff like that easy.
so when you use longer shackles what size bolt do you use? Do you just get an 18mm or do you make a SAE grade 8 fit somehow?
Wicked Raciest !
Originally posted by Ben:
<STRONG>so when you use longer shackles what size bolt do you use? Do you just get an 18mm or do you make a SAE grade 8 fit somehow?</STRONG>
I use 3/4" grade 8 with steel lock nuts.
1 - 8 of 8 Posts
