1 - 20 of 25 Posts
Moderating Midget
Decisions, decisions.....
My goal is to stretch my wheelbase within reason (no frame cuts yet) during my axle install/spring over.
For the rear, I am installing 55 springs.
Thought #1: Leave the shackle hanger in its stock location and use one of these God-aweful 3" shackles that I am using for my SUA at present. I am thinking that this will give me a 45 degree angle on the shackle for a nice smooth ride, plus the droop should be wicked! The long shackle should not give me much additional lift since it will be at an angle.
Though #2: Front FJ-40 springs reversed with the military wrap on the shackle reversed end (front) stretching my wheel base another 3 inches to the front. I am thinking about picking up some "new" Cool Cruisers stock springs for $80 each to do this.
Thoughts? Suggestions?
<IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce.gif" border="0">
Nolan,
It is Matt, before you buy the springs from Cool Cruisers check out my stock springs. I will trade you my springs and some $ for your alcans. Just a thought. Let me know if you are interested.
Moderating Midget
I have a stack of pancake FJ-40 springs that I can get for free. I was just tossing around getting new springs instead.
Just a thought....maybe they would last longer/flex better/give more lift???
I don't know <IMG SRC="smilies/confused.gif" border="0">
Nolen -
If you flip the front springs and keep the wraps where they belong, then you have to do some redrilling.
Heres an idea: Get Alcan to make you the single leafs that you would neeed to redrill, custom to your spec. That way it can be any increase in base that you want.
Moderating Midget
The wraps belong on the fixed end of the spring right? If that is the case, they will be in the right place when i do the shackle reversal, right? <IMG SRC="smilies/confused.gif" border="0">
Originally posted by wngrog:
<STRONG>The wraps belong on the fixed end of the spring right? If that is the case, they will be in the right place when i do the shackle reversal, right? <IMG SRC="smilies/confused.gif" border="0"></STRONG>
Yessir!!! you are completly correct!!! What type of steering are you going to do???
Hey, my 38.5's show up today. I should be able to mount them by this weekend!!! Gonna get some new flex pics!!!
Did the pic I sent you do you any good??
I know is was rough but it should give a basic idea. Unfortunately I am not the graphic artist like a lot of the guys on this board are.
Moderating Midget
I am going to have my tie rod behind the axle and hydo assist.
Send me some shots!
My buyer took the 38's home, installed them on his Jeep and they f'ing don't fit!
I still have tires for sale! <IMG SRC="smilies/mad.gif" border="0">
Oooooo hydro assist huh. Cool, that the tie rod is behind the axle. When you do a spring swap and do the shackle reversal it can get a bit tight as a result of the short distance between the axle and the spring mounting point. Compound that with the angle that the spring has to be to get it to the frame... Sounds like a really neat set up though!!!!
Now lets see I need some dana 60's, that extra saginaw box so I can do hydraulic assist steering (You out there clay??? <IMG SRC="smilies/wink.gif" border="0"> ) And a crawler box for my truck... Moab will be fun next year....
I was thinking of hitting the hammers over Thanksgiving. anyone up for fried turkey ala sledgehammer??????
<IMG SRC="smilies/bounce.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0">
Sounds like that will work out very well, Nolen... Are you going full width??
I would think about pulling the overload leaves out of the rear 55 series springs, and adding them to the front packs in whatever layer, to stiffen the front and soften the rear. You are gonna have a traction arm in the rear right??
This will even up the flex front-to-rear, so the front doesn't do all the work. If you wanna get really custom, inboard the rear springs to make them the same distance apart as the fronts, that would be killer, but stock LC springs are probably too soft to have that setup be safe.
I think you're gonna be happier spring over
Good Luck!!
I did spring over on my cruz and reverse shackle. In front I Flipped the spring and gained 3" I tried it the other way and it steered like crap so i think its right if you turn them any way I also turned my rears to gain room for my th400 and D60 gained 2.5" its been fine since alot of flex. never know until you try Is my moto.
69 it looks like you have the pig springs in the back of your cruiser. Is that true? Or did you move the rear shackle hanger forward?
Moderating Midget
Discussion Starter · #14 ·
69...do you ever have problems with the shackle geting suck after to compress it? I was thinking that may be a problem.
As for the front, is the military wrap on the fixed end or the shackle end?
<STRONG>I am going to have my tie rod behind the axle and hydo assist.
Send me some shots!
I still have tires for sale! <IMG SRC="smilies/mad.gif" border="0"></STRONG>
How much do you want for the tyres? Probably not worth me asking as the freight would be too much to Australia but I would like to compare prices, thnx.
Originally posted by Jason M:
<STRONG>69 it looks like you have the pig springs in the back of your cruiser. Is that true? Or did you move the rear shackle hanger forward?</STRONG>
They are some wagoneer springs, I got from FC187. He helped me plan out the set up for the rear. Shackle hanger is in the same spot as before.
<IMG width=432 height=324 SRC="http://www.pirate4x4.com/ubb/uploads/reardroop.jpg">
<STRONG>69...do you ever have problems with the shackle geting suck after to compress it? I was thinking that may be a problem.
As for the front, is the military wrap on the fixed end or the shackle end?</STRONG>
Im not understanding the first question, but I havent had any problems with it yet. The wagoneer spring is real close in length to the 55 spring also.
In the front I flipped the 2nd spring with the wrap around so that it would be at the fixed end. I took it to a spring shop to drill it for me, cost me 10 bucks.
<IMG width=360 height=270 SRC="http://www.pirate4x4.com/ubb/uploads/frontend22.jpg">
Originally posted by 69cruzer:
[QB]They are some wagoneer springs, I got from FC187. He helped me plan out the set up for the rear. Shackle hanger is in the same spot as before.
How long are the Wagoneer springs? Are they close enough to the fj55 springs that the longer shackle would still work? I think it'd be great if I didn't have to move the rear hanger. Thanks!
Originally posted by Fullsize 40:
<STRONG>
How long are the Wagoneer springs? Are they close enough to the fj55 springs that the longer shackle would still work? I think it'd be great if I didn't have to move the rear hanger. Thanks!</STRONG>
the wagoneer springs are a little shorter (maybe an inch or so) than the 55s. I didnt move my hanger. I think you could do the same thing with the 55 springs though.
1 - 20 of 25 Posts
