1 - 6 of 6 Posts
finally doing a spring over on the samurai, just trying to find some good info on what is required or needs to be done besides welding on new perches, ie, the steering, what all needs to be done to make things go smooooooothly, any help is appreciated..
if you go spoa you must flip your U-bolt plates from left one on the right and right to the left. go with drop pitman arm or high cross over don't go with Z-link. if you are looking for suspention, make higher shock mounts for the front. stock chevy break lines work great, a little longer and stronger.
Originally posted by Mudmagnet:
<STRONG>if you go spoa you must flip your U-bolt plates from left one on the right and right to the left. go with drop pitman arm or high cross over don't go with Z-link. if you are looking for suspention, make higher shock mounts for the front. stock chevy break lines work great, a little longer and stronger.</STRONG>
Why not a z-link?? I've never had trouble with mine.
<IMG SRC="smilies/confused.gif" border="0"> <IMG SRC="smilies/confused.gif" border="0">
...you must flip your U-bolt plates from left one on the right and right to the left...
FYI, the front u-bolt plates are not interchangeble side to side. The passenger side has about 1/4" wider spread on the u-bolt holes and the u-bolts are wider to clear the huge Sami differential <IMG SRC="smilies/biggrin.gif" border="0">
I agree that you need to make (or buy) new upper shock mounts for the front. Don't forget that you need new lower shock mounts all the way around.
ok, I understand that in the rear I can swap the right and left u-bolt plates and use for lower shockmounts, I can make my own for the front(Lower) but what about the upper? just wondering if anyone buys some other brand and welds them in. like on the toyota you would use f-250 shock towers. anybody try anything like that. and what is the z-link? pictures???anybody? thanks for the help.
1 - 6 of 6 Posts
