1/2 inch would be way overkill for a Willys, especially if it's still SUA. You would tear the spring mounts off the frame before you broke a normal 1/4" spring plate.Keith Strong said:1/2 inch plate, drill press![]()
Sure, but both are normally scrap pile findingsoldjeep said:
1/2 inch would be way overkill for a Willys, especially if it's still SUA. You would tear the spring mounts off the frame before you broke a normal 1/4" spring plate.![]()
it's from applying the go pedal, the more you apply the more wrap you have. Course it's also engine dependant. And even 6" long perches wont get rid of it.DDGETHS said:Is axle wrap more from getting on it or wheeling hard than it is from what most of us would call "normal" driving?
I'm thinking about making some spring perches that are 6" long. This would help some.
