1 - 2 of 2 Posts
I can't seem to get the bolts out that holding the springs in the hanger and shackle is there some sort of trick I need to do to get these things out or should I just torch them. Also what size bolt do I need for the wrangler springs?
Wicked Raciest !
Originally posted by CruiserNut:
<STRONG>I can't seem to get the bolts out that holding the springs in the hanger and shackle is there some sort of trick I need to do to get these things out or should I just torch them. Also what size bolt do I need for the wrangler springs?</STRONG>
Cut them with a sawzall or torch them. What size are the holes in your new bushings? That is the size you need. Use grade 8 with a metal lock nut, not a ny-lock. I have drilled all of mine out to 3/4"
1 - 2 of 2 Posts
