1 - 2 of 2 Posts
I had made the mistake of hooking up an SR5 Dash without changing the oil pressure sensor and had no oil pressure reading. I changed over to the SR5 sending unit and went to Cal Mini Trucks and got another dash and it still has no oil pressure reading. I see 13.7V on the sensor. Is the sensor OK? What is the typical resistance of the sensor? Has anyone tested the gauge with a potentiometer on the sending unit wire?
Discussion Starter · #2 ·
FAQ says there's two different SR5 sending units. I have the small one so I'm guessing that I need the larger one which probably has a lower resistance.
1 - 2 of 2 Posts
