My Scout will turn only turn over very slowly. It is like it is not getting enough amps........could this be the starter? The grounds are good. New Painless kit.
What he left out.....Rubicrawler said:Could be you have a bad cable going from the battery to the starter. Does your positive cable get really hot? I had the same problem and fixed it by installing a Ford solenoid on the firewall and bypassing the solenoid on the starter. I also replaced the cables with new, heavy gauge cables. No more problems![]()
"I dicked around with it for two weeks, this really smart guy I know recommended the Ford Solenoid. I blew him off, figured what the hell does he know. Spent another two weeks messing with it, installed a new motor, transmission, axles and bunch of other sheet. Then my wife reminded me what the smart guy said about the solenoid. So down I went, bought the 10 dollar part and some new cables. What ya know the Scout started right up with the solenoid"
:flipoff2:
well when i had a 392 in my scout...the starter did the same thing that you described...i put a new one in. Worked great, then it started the same thing about 4-5 months later...i thought that it was just getting too hot, so i would bang on it with a wrench and it would start up everytime.TravisSSII said:My Scout will turn only turn over very slowly. It is like it is not getting enough amps........could this be the starter? The grounds are good. New Painless kit.
