1 - 9 of 9 Posts
Wicked Raciest !
gnob said:
yeah i know but i thought i remeber pirate consensus to be go for 80 and lots of red loctite :flipoff2:
Not that I know of, there is a reason for torque specs. Going over a torque spec stretches the fastener and makes it prone to failure. :grinpimp:
When Opp's tells ya, you need to listen!!!!!!!!!!!!
I'll try and post some info later about modifying the knuckle to use Grade 8 Dana 44 9/16" studs, with OTT arms with the holes all set up for it. Not as easy as I thought .... If I fawk up one hole, I have a new paper weight ...
Wicked Raciest !
Not always, but if I find I made a mistake I will be first to admit it!!!! :grinpimp:
Did you get rid of those 4x4 Lab arms?
1 - 9 of 9 Posts
