21 - 28 of 28 Posts
Mine leaks down off of the shaft for the pitman arm. Does that mean I screwed up the teflon seal on the inside while tapping for hydro?
no it doesnt mean that you did mess up the teflon seal it means you might have. there is a regular flap seal on the outside , the teflon seal is inside a snap ring that is between it and the flap seal.
heres a good write up i found.
http://128.83.80.200/taco/box.html
Does anyone have the p/n or a source for fj 60 box rebuild kits? Mine leaky leaky when it gets warm.
go to your dealer and ask... ypu can also look it up on www.trdparts4u.com with a year make and model search. if you cant figure out which one call the dealer or go in with a list of all the possible p/n's and see which one they show on the computer or microfiche.
Can anyone confirm that this kit works on '86-'89 steering boxes? I called my local dealer and they told me the seals are only available individually. I've got a call into my preferred dealer to see if they have any better info.
i ordered the same kit that oops litsted today from toyota of dallas and they wanted my vin number , i gave them the vin from the 87 runner out back and they told me the part wont fit this truck and that its for the late box, ive inspected the cross shaft gaskets/o rings and seals and put a mic on the cross shaft on both style boxes and there is absolutley no difference in that part of the box. you can actually take the cross shaft out of the late box and put it in the early box and vice versa. i told them to just ship the damn thing.... seabass you get yours yet?
didn't come yet, got my new 5" TG rear leafs to match the front though:)
just did a sas on my Buddy's 90 4runner, these are way soft,will flex insane!
yea i just helped a guy do an 86 sas using tg's kit, i hate cutting the frame tube holes!!!!!! lots of mud/sand and trash in his frame. those springs are very soft and flexy. i have the front/ rear tg kit too and it flexes as much as my tires will let it. the springs are worn out though they only lasted about 18 months of wheeling nearly every weekend, pretty normal and expected. ive got a new set sitting on the garage floor just too damn lazy to swap em since ive been building a flatbed/partial exocage
i tried to source the flap seal for the cross shaft, aka pitman shaft seal on advance discount auto's site and the parts we cross referenced skf part number 14004 with national part # 710343 which i found at car quest ,the cross referenced part does not fit on the od in the box but the id fits on the cross shaft perfectly . i coudnt find 14004. i said fugg it and bought some ramen noodles so i could buy the seal kit from trdparts4u :smokin:
21 - 28 of 28 Posts
