My 89 has a tilt and the thing is WRECKED, the torx head bolts that hold it tight are stripped out and its got the weeble wobble of death. I went to PAP at lunch and snagged a non-tilt column out of an older bodystyle truck (basically all they had and the mounts seemed to be similar close enough. Outside of wiring anyone know what else I will be in for to make this column work? Im glad its a non tilt cause I lean on my wheel ALOT so I figured down the long road this wont be an issue again. Either way Im going to make this column work, just wondered if anyone else had ran into this problem .
