1 - 11 of 11 Posts
Did a 302 swap into my 95 runner and now my power steering fluid boils within a couple mins. I am still using the original toyota steering box but with the ford pump. I heard about a mod where you drill out the orifice in the steering box? but cant seem to find it anywhere on the net. Any ideas? power steering works great but boils really easy. Im not talking about hydro assist or anything just strictly ford steering pump and toyota steering box. Thanks guys:confused:
What fluid are you using?
Are you running any sort of cooler? Or just the sucky 2lines that run under the fan.
You sure it's boiling, and not sucking air in from a leak created by converting to a new pump? Could just be aerating causing it to bubble up.
full on boil and pissing everywhere. no cooler right now just the two lines. i have a electric pusher fan on the front side of the rad. running amsoil atf fluid. this was the first time outta the shop since the transplant and i only went around the building to our rti ramp to check suspension clearances and it boiled. had to let it cool then it boiled again getting it back into the shop. does the ford pump build more pressure than the toy box can handle and it doesnt have any where to go? steering works great but lasts 5 mins
Discussion Starter · #10 ·
Popped the cap on the ps res and found there was no dipstic left and bottom of cap was all melted too. Fired the engine up and ps pump makes wicked squeal. I think it got a just little too hot. Guess its time for new pump. Maybe that will solve my problem... Hopefully?
1 - 11 of 11 Posts
