1 - 4 of 4 Posts
self-fullfilling prophecy im sure.....
Heres the setup: High steer passenger arm has 2 holes: tie rod is 5.5" from balljoint, draglink is 7.5" from balljoint.
You're supposed to have a pitman arm = to the distance between draglink and ball joint, so 7.5" long.
Looking at using a dropped pitman arm from a wagoneer, which is only 6.5" long. Immediatly this tells me I should connect the draglink to the tie rod, at approxiamtly 3.5" inwards from pass. side tie rode TRE.
At center, this puts the draglink 6.5" away from the ball joint (good ole a^2+b^2=c^2)
Now the problem I see, as the system is turned its going to change the distance between the ball joint and the draglink TRE.
What am I missing here? I'm sure its something obvious :mad: :confused:
Are you trying to say that that a stock steering system remains constant when turning? :confused:
Sector shaft to draglink at pitman equalling kingpin axis to draglink at steering arm only means you are maintaining a 1:1 ration between the two. Moving the draglink at the steering arm outwards will create more steering force (and slow the ratio), moving it inward woll remove steering force (and quicken the ratio).
1 - 4 of 4 Posts
