1 - 6 of 6 Posts
I just finshed my high steer and was wondering what was wrong with it, it steer's go at low speeds but at high speed it seems to be really stiff and like it is not getting power. Could it be the steering stabilzer. And do you have to bleed and system the book says use dexon 2 but wouldn't you use power steering fluid. need help
Wicked Raciest !
Bad Karma said:
Yeah, the book's wrong. Put power steering fluid in there and see what happens.:confused:
Damn noobies, use the ATF like it says. :rolleyes:
So do I, when I put PSF in mine the pump started leaking the next day!! Talked to the Toyota Tech neighbor and he told me that they say ATF for a reason and if you use PSF the pump will start leaking.
i ran my truck with power steering fluid for about a year and it never had a problem. strange, it made a lot of noise in the winter but then i learned about the atf and the noise is gone.:rolleyes: live and learn
1 - 6 of 6 Posts
