OK so i spent the day out in the driveway trying to get my DW & sloppy steering to go away. first i put a couple of spacers under the kingpin springs. second replaced all the bushings on the springs (the shackles are in the front not reversed) and hangers. third i added a few trusses to th rear spring hangers (thinking they might be wobbling)
i test drove it, no dw up until about 30-35 mph. then i could be on one of them chocolate milk commercials. :flipoff2:
this is next up on my list of fix/make better.
my box is a new CJ box with a waggy pitman arm. replace with wangler box and steering shaft to get rid of my worn out bell joint. (could a worn bell joint be causing dw?)
then if that dont work throw on some hydro assist.
then if that dont work you think a panard bar would help?
or going to shackle reversal?
any comments on what i should do different?
my tires are unbalanced 39 TSL's
