1 - 2 of 2 Posts
couple of general questions about steering shaft joints
Do the same max operating angle rules that apply to driveshaft joints apply to steering joints? Obviously they aren't going to rotate as many times
If the angle is steep does it require more turning force? Does a joint at 15 degrees take less force then 30 degrees.
Ive always just thought that if it doesn't bind and clears everything then run it.
arndog
1 - 2 of 2 Posts
