1 - 14 of 14 Posts
Need help with a 77 CJ 7. It has 2.5" lift and 32 12.5 15 tires. It wanders all over the road. I took it to a 4x4 shop in So Ca and they said all looks good except the ball joints seemed tight. Replaced ball joints, drag link, tie rod ends and rebuilt steering box. All with no luck. The toe is set about 1/8" in as I don"t know the correct setting. In any 4x4 I"ve owned (mainly jeeps over the years), if you turn in a circle and let go of the steering wheel, it will return to center. My jeep just keeps going in a circle. Not fun. I"ve checked for cracks in the frame where the box mounts and can"t see any. Any ideas as it is no fun to drive in the back country roads of Tn. Thanks for all your ideas.
I had one do that and I toed in and it got worse. Then toed out one full revolution at a time until I got it right. It ended up at about a 1/4" in or so.
longer shackles will only make caster less. If you get longer shackles run some shims. Also try a bit more toe in maybe 1/4" but no more than that.
if there are currently shims on the front make sure the thick part is towards the front
Also check the tierod ends... a freinds stock CJ-5 acted the same way with warn out tie rod ends... also killed a pair of tires on an 500 mile road trip
Discussion Starter · #13 ·
I want to thank everyone for there suggestions. As a last resort I cranked the toe out about a 1/4" and it drives much better although it needs fine tuning. At least I know I can live with it. I will also look into those caster correctors. Yes, the axle is shimmed with the wide side to the front.
1 - 14 of 14 Posts
