1 - 2 of 2 Posts
Qeustion about a stock T-case. I was wonderining if there is anyproblem with them holding up. i'm new into Suzuki stuff and was out wheeling the other day not even doing anything crazy and my T-Case shit the bed. It wont go in 2 wheel or 4 wheel high or low. it drives for about 2 feet and then its kicks out. Just wondering if anybody has seen this problem.Also How much is a used T-case worth so I don't get dicked buying a used one! Thanks For your help.
By the way I have a 4.3 and 33's thanks again.
SCott
The t-cases seem to hold up ok. It may be that your t-case mounts are seriously twisted and the t-case is fine. Your symptoms sound like that to me. With a 4.3, 33's, and stock R&P gearing, that t-case is under some SERIOUS <IMG SRC="smilies/eek.gif" border="0"> stress. When I bent my mounts, it was hard to get into 4 wd and then it would pop out easily. My mounts weren't even bent all that severely. Anyway, check them if you haven't already. It is a quick check and a cheap fix. Good luck.
1 - 2 of 2 Posts
