Hello everyone. My TJ was just stolen from my apartment last night in Quincy, MA. Below is the picture and specs. If you see anything please call 911 and me as well 203-423-9102!
2001 Jeep Wrangler Sport (steel blue)
4.0L Engine
NV3550 Transmission
np241 transfercase
5.5"CLAYTON long arm suspension lift
-rear triangulated 4 link
-rear 6" custom stretch
-front Y link with 1" stretch
-Clayton custom track bar (builder kit)
-Bilstein 12" travel shocks
-3/4" spring spacers in rear
39.5x13.50 IROK's
17x9 Black Rock Steelies
A/C converted onboard air
D44/D60 Hybrid front axle (62.5" WMS)
-F250 D44 housing with 35 spline ARB air locker and 4.88 gears
-D60 35spline shafts(inner and outer)
-SOLID D60 inner C's and knuckles(5x5.5 bolt pattern)
-SOLID high steer arms
-Teraflex high steer axle bracket
-1 Ton HD High steer set up
-35 spline warn premium hubs
GM 14 bolt rear axle (62.3" WMS)
-CLAYTON high clearance bracket kit
-Rock Crusher 5x5.5 hub kit
-Disc brake conversion kit
-Yukon Grizzly locker with 4.88 shaved gears
-Ballistic Fab shave kit + Diff cover
-WFO Concepts Pinion Guard
slip yoke eliminator kit
TOM WOODS front drive shaft
Rear Custom CV drive shaft
Genright rear crossmember
Genright EXT Comp tank (YJ style custom fuel filler)
WARN front custom stubby bumper (Custom as in I took a saw zaw to it)
AtoZ winch plate
WARN rocker guards
WARN steering box skid plate
WARN M8000i winch
bedlined tub
CLAYTON high clearance Tcase and engine/oil pan skid plates
HD clutch kit
K&N cold air intake
SPINTEC exhaust system
TNT ARMOR
-Front HyLine Zeros tube fenders (paint matched + Custom work)
-Rear HyLine Zeros corners (paint matched)
-Body mounted swing out tire carrier
-Custom one off shock hoop kit built to order
PSC HD steering box ported for Hydro assist
chrome headlight bezels and grill inserts
DDM Tuning HID headlight kit
IPF H4 headlight housings
ALPINE head unit, Ipod interface, Sirius and upgraded speakers all around
Mastercraft Rubicon sport seats and harnesses with Synergy harness bar welded in
hardtop, soft top, duster, bikini, safari top
Tuffy Security box in back with risers and divider kit
Custom cut HyLined hood with Rokmen hood pin kit
ORO Lite Dot Tail lights
Optimum Yellow Top Battery
4.0L Engine
NV3550 Transmission
np241 transfercase
39.5x13.50 IROK's
AtoZ winch plate
WARN rocker guards
WARN M8000i winch
bedlined tub
HD clutch kit
K&N cold air intake
TNT ARMOR
