I am looking at a cheap fix. Would like to sell the 35 when I upgrade. Oh and I had to drive 240 miles in four wheel drive with my rearend making a whole lot of noise even after I cleand out the metal chunks on the trail.gavan said:Put it in four wheel drive so you can drive around on the front axle untill you can learn to search.
alright, i cant be that mean. the next logical step from a 35, even on a stock vehicle is a duece or mog setup.
gavan said:i give up. move it quick!
how much is a lock right? how much is a welded 14 bolt?Neal'88yj said:I went through the same thing, get the lockright till you can upgrade. some people on this board don't understand what a budget is.
I do suggest upgrading in the future.
first of all , yes you are a dumbass. second of all this is a hardcore rock crawling tech forum, thirdly theres a thing called the newbie forum where you would have gotten more and better replys if you posted there .Dingus said:
I thought this was a place to ask questions. Look for advice. Yes I am a newbie but I am not a dumbass.
I second that....some people dont understand that a budget is one step up from being Po'.Halogrinder said:weld it
Look noob, I know you are trying to look all badass and such, but driving a 35 without a carrier is the dumbest thing I have ever heard, unless this guy actually drove 240 miles with no fluid in his diff, that would be the dumbest thing I have ever heard...gipper said:you're not?
you drove 240 miles with metal and no fluid in your r&p. Even if you filled it back with fluid, the carrier was still turning out chunks of metal for grinding in your r&p. If you wanted to avoid the dumbass comments, you shouldn't have driven it or at least pulled the carrier and driveshaft.
edit: oh and you DEFINATELY should have put the original in the newb forum instead of JEEP TECH :flipoff2:
AND, one more, I'll bet you had your spider gears welded didn't you?
umm im quite aware it is now in the noob forum, it wasnt at first. i was just letting him know why he is a dumbass and how to correct itCue-Ball said:
Second, Dingus, Lurk around without posting for a little bit and you will inderstand why people reacted the way they did at first.
and Third, EXO, you are correct that it should have been in the n00b tech forum but that is why Mo's post with the cow signaled that it had been moved to the n00b forum.
Q
good luckWould like to sell the 35 when I upgrade
Because as soon as it gets moved, the attitude should go away. No more explaining to people (like you) why they are dumbasses (like you are). So, now that it's here, people gotta keep it zipped unless they can help...or, unless some mouthy fawk (like you) needs to be yelled at by someone (like me).EXO said:
why in the hell are you telling me to chill? are you the pirate mental helper? this isnt chit chat
