1 - 3 of 3 Posts
I got my lift installed and I am trying to install the new pitman arm however it will only go on the vector shaft half way and then sieze. If I use a socket and try to hammer it farther it won't go. So I got the old one and it does the same damn thing. I cleaned the splines on the vector shaft and it still does it. I tried using the nut to get it higher but I ended up stripping the nut.
Any suggestions on how the hell to get this thing on?
Discussion Starter #3
naa thanks for the tip though. the problem was that was all the farther it went. there was like 1/2 inch of splines left and the old one fit snug and I thought so did this one but I was wrong.
1 - 3 of 3 Posts
