Figured I would finally start a build thread here for my new buggy.
Last year after beating on my old buggy for a while, I decided that I wanted a bit more motor (had a 4.3 in the old one) and some more wheelbase (had 107 in the old one). I did a bunch of measuring and spent some time laying under the old one and trying to wrap my brain around doing what I wanted….
Here is what I had before and where 90% of the parts are coming from:
I eventually came to the conclusion that it would make much more sense to build a new chassis rather than try to adapt this one to the changes. The old one was just so small and tightly packed in, it would have taken a TON of cutting to get to a point of starting to make things fit.
A friend and I had been talking for a while about building chassis and so we both decided that we would pull the trigger and make it happen. We would build 2 “twin” chassis (I say twins…but there are slight differences in the two to make them fit exactly what we each wanted; but the base chassis is the same on both). We picked up Bend-Tech and some tools and got to work. We took a lot of measuring from my old buggy, his old buggy, and a lot of ideas and styles from some other chassis out there and put them all together. It is no secret which ones are predominately used… :flipoff2:
The basic plans are for the following:
5.3 with a few small/standard goodies
4L60E trans
Atlas
Solid MFG HP60 front and rear from my old buggy
16" ORI STX in rear, 14" ORI STX in front
40” Trepadors on Trailreadys
Shooting for ~110” wheelbase
Front radiator
All the rest of the standard buggy parts
Here is the chassis that we designed in Bend-Tech. There will be some changes made in the final design, but this is basically it.
There is a lot of .188 wall tube in this chassis as I had some dented tubes in the old one and wanted to avoid that as much as possible. Any tubing you see throughout the build that is the dark color is the .188 and the light color tube is .120
There is a mix of 1.75, 1.5, and 1.25 in the chassis.
You will notice another chassis sitting off to the side…that is the rolling chassis that is the twin to this one…it was built before mine. Here it is as a roller and what mine will “basically” look like:
On to the pictures of mine…I am open to feedback and ideas if people see things that they have questions about.
4L60E trans
Atlas
Front radiator
