Ok ill be the first to ask,krankitup said:I have tried it both ways. I had it were I only had .0003 in shims and now I have .006 I'v been doing alittle research and it looks like I might need to give the pinion a tap and to see if the bearing is set all the way.
"what axle you working on"
So based on no information id say try more shim...
In fact id try alot more and work it in from the other direction and NOT ruin things... ?
-yag
What was your final in lb?krankitup said:Ok, I got it, finaly ended up with .0085 in shims. That is almost 3 times what the stock one had on it. Thanks for everyones help.
