on my cj3a I am keeping the under seat tool box and gas tank. so the sm-420 and spicer 18 are staying under the tub. rather than a body lift, I'd like to keep the tub pretty much on the frame. so the 18 will likely hang down as is common. the stock crossmember looks like a rock anchor and I don't have a skid plate.
should I just make a skid plate and use these stock parts, or graft some tubing to the bottom of the frame an inch or two lower the whole length and build a flat belly skid across the hole thing. it will be lower, but smoother to drag over stuff, or am I just thinking too much?
