1 - 20 of 74 Posts
Superchips TrailDash Module, 1998-2006 Jeep Wrangler with 4.0L, 1998-2001 Cherokee, 1999-2003 Jeep WJ Grand Cherokee with 4.7L
Your off-roading and Jeep experience is incomplete without the Superchips TrailDash. The TrailDash is the most advanced Jeep tuner on the market today. The TrailDash was designed by hardcore Jeep enthusiasts and features Superchips' proven street and trail tunes which have been tested in multiple altitudes and climates including the legendary trails at MOAB.
Monitor Features
- 4.3" color touch Screen Transmission performance (Shift point adjustment)*
- Inclinometer gauges
- Customizable digital gauges (Reads numerous PIDs)
- Maintenance Manager (schedule and track maintenance)
- Mileage mentor (track and save fuel)
- Performance tests
- Reads and clears trouble codes
- Expandability (includes the ability to add aftermarket, accessories and sensors via the Superchips EAS
- Monitor includes video input and can run backup or other camera accessories
Program Levels*
- 91-Performance
- 87-Performance
- Heavy Load Towing
- Crawl
- Fuel Economy
- Factory Stock
PIDS
- Battery Voltage
- Battery temperature
- Corrected Speed
- Engine Coolant temperature
- intake Air Temperature
- Engine RPM
- Fuel Level
- gear Ratio
- Run Time
- Trip Odometer
- Trans Temp
Pitch and Roll Screen Pids and Options
- MPH-C
- Run Time
- Gear
- ETC
- Battery Temperature
- Fuel Level
- Battery Voltage
- IAT Temperature
- Trip Odometer
Off Road Features Screen 2 PIDs and Adjustable Options
- Crawl Tune for low speed off-roading
- Tire size, axle & transfer case gear calibrations
- TPMS threshold adjust
- TPMS off-road feature
- Real time idle up for threshold accessories
Custom Options
- Speed Limiter Adjustments
- Maintenance manager
- Mileage Coach
Data Logging
- Log and store up to 10 unique logs at a time
- Log hours of data
- View and graph logs on your PC using the new MyStyle software
- View all parameters or pick which ones you want to view
Screen 2 PIDs and Adjustable Options < /strong>
- Engine Idle
- Timing
2007-2010 Rubicon Specific Features
- Digital touchscreen front and rear axle lock
- Digital touchscreen sway bar lamp on/off
- Daytime running lights adjustability options
- 4WD-HI axle lock with auto-disengage safety features
Diagnostics < /strong>
- Trouble Codes
- Performance testing
- Records
* NOTE: Features vary be year, make, model and engine. Search by vehicle in question to find out the details. All Superchips tuning products for gasoline-fuled vehicles are either covered under CARB Executive Order number or are in a pending
Superchips TrailDash Module Dash Pod, 2007-2010 Jeep JK Wrangler with 3.8L
Superchips TrailDash Module Dash Pod, 1998-2006 Jeep TJ Wrangler with 4.0L
1 - 20 of 74 Posts
