1 - 20 of 24 Posts
for the rear of my cj, i got a centered scout 44 and for the front an offset waggy 44. the front is disks and the rear is drum. my question is, would it be better to swap from 5 to 6 lug or 6 to 5 in order to match up and should i drill them or buy a kit? i would prefer to be 5 lug, but i didn't know how much of a pain it was to deal w/ the converting the disc brake diff..
thanks....
russel
Super Moderator
'82 Scrambler, '14 Rzr
It would be easier to swap the front to be 5 lug to match the rear than to re-drill the rear to match the front.
You should be able to get the necessary 5 lug outer 44 parts to convert off of a Ford F150 Dana 44 front <IMG SRC="smilies/smile.gif" border="0">
i have done this.. convert the front to 5 lug.. you will need a chevy d44 spindle.. thats 77 or older front axle.. or get a 10 bolt spindle.. and have it machined down for the ford inner bearing..
the rest is ford rotor/wheel bearing hub and locking hub..
i used the gm caliper mounting brackets with wagoneer calipers..
write up no my webpage with more specifics..
If you have a scout rear @ 5.5 and a Waggy front at 6 lug, The conversion is pretty simple.
To convert the front to 5.5 you take the knuckle assembly and the short shaft from a scout or another 44 front thats 5.5
For me I went the other way I went to 6 lug on mine.
I might be able to set you up with the 5.5 knuckles and short shafts if your interested.
Steve
thanks a lot for the replies guys. very helpfull.
steve- i'd be very interested and appreciative if you could help me out. thanks alot-
russel
Originally posted by WheelingPiazza:
<STRONG>If you have a scout rear @ 5.5 and a Waggy front at 6 lug, The conversion is pretty simple.
Steve</STRONG>
Ok, I heard back from my friend,
He doesnt have any scout stuff at the moment, but he commented that you can use Ford our dodge outters with out changing the stub shaft and get 5.5 and internal hubs.
I did email him back asking him what ford but I would suspect bronco or f150..
Super Moderator
Originally posted by NE-RokToy:
<STRONG>Everyone forgets to mention the setup for 5 lug is wider then 6 lug so if your worried about width stay 6 lug</STRONG>
swapping from 5 lug to 6 lug only adds roughly 1.5" to the overall width - not something I would be to worried about (the fornt should be 1" or so wider than the rear anyways, and you could still run spacers ont he rear if needed).
As for which Ford parts to get 5 lug, I said that at the very beginning already <IMG SRC="smilies/wink.gif" border="0">
<STRONG>He doesnt have any scout stuff at the moment, but he commented that you can use Ford our dodge outters with out changing the stub shaft and get 5.5 and internal hubs.
</STRONG>
He can use his existing stub shaft only if it is a '74-early '77 Waggie axle. The late '77's and up use a larger inner bearing (inner diameter) than the Ford hubs require. Jeepgod's site as he mentioned has a complete list of what is necessary to make the swap to a 5 lug front along with a good writeup. It's a really easy swap and parts are also easy to find and cheap to replace.
Discussion Starter · #12 ·
thanks a lot JEEPGOD, that write up has definately solved the problem and i really like the 'homemade' shackle reversle. thanks everybody for the opinions. ford parts seem the way to go now(just because i know i can get them all w/o a problem). -russel
Originally posted by DRM:
<STRONG>swapping from 5 lug to 6 lug only adds roughly 1.5" to the overall width - not something I would be to worried about (the fornt should be 1" or so wider than the rear anyways, and you could still run spacers ont he rear if needed).
As for which Ford parts to get 5 lug, I said that at the very beginning already <IMG SRC="smilies/wink.gif" border="0"></STRONG>
Yeah but if I rememebr right the wagoneer front axle is alread 1.5-2" wider then the scout rear he has so the front could be as much as 4" wider, thats a big differance to me
Originally posted by CSP:
<STRONG>He can use his existing stub shaft only if it is a '74-early '77 Waggie axle. The late '77's and up use a larger inner bearing (inner diameter) than the Ford hubs require. Jeepgod's site as he mentioned has a complete list of what is necessary to make the swap to a 5 lug front along with a good writeup. It's a really easy swap and parts are also easy to find and cheap to replace.</STRONG>
Stub shafts don't matter (with the Waggy axles) it's the spindles that are different.
let's get this shit straight
I am digging this up from the grave, so tune in closely.
Are Dodge stub shafts similar to any other manufacturers stub shafts? I am using dodge parts from the inner C out to do the 5on5.5 bolt pattern change and the high steering, but cannot find out info on the dodge stub shafts. What do the dodge donor conversions do for stronger stub shafts? (alloy)
Are the stubs the same dimensions as chevy or waggy?
1 - 20 of 24 Posts
